Ideas for CCleaner
I have used this software for quite a while now, and am extremely happy with it. But as an extra bonus, why not include the following features:
1. Ability to clean old System Restores - Although I don't even have this component installed, some user do; some may wish to remove System Restores from certain dates thta they will not need.
2. Ability to clean old Non-Used Driver Files - Another novel idea. The abilty to clean-up old driver files that aren't in use. Almost all hardware you buy now comes with driver installation disk. And after you have your OS completely installed there is no need for the old driver files which you never use to remain on the computer.
3. Ability to remove "Excess" Components from the Microsoft OS - For instance:
Windows TourWindows HelpExtra Language FilesExtra Keyboard Layouts
These ar ejust a few of the ideas floating around in my head. But i think if CCleaner was expanded to remove all of those types of files, it would be for the betterment of the program. Also I think these options should ALL be listed under an "Advanced" tab, with warnings as some of these can cause serious dmaage to a system if you are not sure what you are doing.
