Icon Problems
Hi.
I have used older versions of ccleaner before and have never had a problem, but with version 5.12.0.5431, some of my icons have become skewed.
First, my Chrome Icon disappeared from my Taskbar (well it changed to a 'white page' -looking icon) and now my MusicBee icon just changed right after running ccleaner, into a weird folder-looking icon.
I tried to rebuild my icon cache, but it didn't correct anything.
Thoughts?
What operating system are you using?
Are you using the registry cleaner?
Have a try of the latest Ccleaner 5.17
http://forum.piriform.com/index.php?showtopic=46140&do=findComment&comment=272987
Please try 'iconfix' (in the attachment).
The problem you describe has more to do with Windows than with CCleaner, I think.
iconfix.zip
