I will stop using ccleaner
I used ccleaner free since many years but now i think i will stop. The reason is i do not appreciate ccleaner 7 because it is not possible to choice the installation path . My windows 11 has a small main hard disk so i use an external disk… This was possible with ccleaner 6 but if i try to install ccleaner 6 only ccleaner 7 is installed! maybe a new release to solve that? Thanks
For the download link(s) and roll back instructions click this: How to Roll Back from v7 to v6.39
thanks nukecad for the fast reply. I will try with your link and hope to continue still long with ccleaner.
hello nukecad, i have tried you link, unchecked the automatic update case in ccleaner 6 and now i can choice the installation path and for me ccleaner is now working fine again. Many thanks to you.
