I quote a review of FreeRamPro!
"In practical, if you try to free memory on RAM, windows will write the necessary files or cache on hard disk instead which will drop overall system performance".
I have 1G of ram and 66.6Gs of free hard drive space. Would this app make any sense for me at all? Thank You!
http://www.download.com/FreeRAM-XP-Pro/300...j=dl&tag=button
1 gb of RAM is alot and should be enough.
I dont think you need it. But restart the computer once in a while.
I also don't think you need it especially since you have 1 GB of RAM. Some caution needs to be used with the RAM refresh/defrag programs as I remember a few years ago when some of them were messing up systems when users were trying to free too much RAM.
Edit:
For some reason I've noticed over the past few years that running Ad-Aware's smart scan seems to refresh the memory.
could not having free ram be my problem to. Every now and then when i try plaiyng BF2 it just does not work. If i try turing off my computer just before it shuts down it gives me a weird error. it gives numers like 0x000000 or something along that line what is that?
Is this the same pc you just built and were having problems with? Test you ram for issues with this:
http://www.memtest.org/
sorry i am sort of new to bootable thing like this. So i need to download one of the bootable thing then do what from there? I don't have a floppy drive so i can't make a bootable floppy and thats the only type i know how to make.
so i guess no ones going to help me?
@ Vanguard382
The Memtest86 website has a downloadable .ISO package that will allow you to create a bootable CD-R or CD-RW. Just load the .ISO with your CD recording software and burn a disc as usual to create the bootable CD. Then place the disc into your CD drive that boots first and restart Windows.
Edit:
Forgot to mention: Use the Windows boot menu to start from the bootable CD.
