I need instructions to exclude a registry key:
Unused File Extension {80b8c23c-16e0-4cd8-bbc3-cecec9a78b79} HKCR\{80b8c23c-16e0-4cd8-bbc3-cecec9a78b79}
The CCleaner dont remove.
Thanks.
Thanks.
Thanks.
This is a file extension from the new Antivir 9. I believe it was in the old versions also as a search from Google showed this forum and a mod expressing concern about it back then. I have the same problem and it seems in use but has the incorrect path. I have made a topic about it here with no help either.
http://forum.avira.com/wbb/index.php?page=...;threadID=85175
Boot into safe mode and you'll be able to remove it.
HTH
I've excluded that key before when I used to use AntiVir and CCleaner's built in exclude wouldn't allow it, so it has to be inputted manually.
There's only one way to get it to exclude:
Save all settings to INI file
C:\Program Files\CCleaner\ccleaner.ini
Exclude3=REG|HKCR\{80b8c23c-16e0-4cd8-bbc3-cecec9a78b79}
- Start CCleaner, then click Options->Advanced, now tick:
- Close CCleaner.
- Open Notepad, then open this file with it:
- If you have other exclusions they'll be listed in ccleaner.ini, and this new exclusion must be in alphanumerical order, i.e.; if you already have say two exclusions like Exclude1 and Exclude2 this new one must be Exclude3.
- This is the exclusion to put into ccleaner.ini, note that the Exclude number is just an example since I don't know what exclusions you already have:
Ok, removed, thanks...
"This is a file extension from the new Antivir 9"
You may wish to include this in their feedback/forums. Thanks
Start CCleaner > Options > Exclude > Add Registry > HKCR >{80b8c23c-16e0-4cd8-bbc3-cecec9a78b79}
Registry key exclude.
What happens if you don't exclude this key and it gets deleted?
There's a much simpler way.
Just right click on the file name and CCleaner gives you the option to add the file to the exclusion list.
