So if i check my CPU, it says "Intel Core i7 7700" (with "Speccy")
but if I check the specifications of the CPU it says that the CPU is a "Intel Core i7-9700K CPU @ 3.60GHz"
I am not sure if this is normal, and I would just like to know if something is wrong.
Thanks.
Speccy for desktop is in quite a need for an update. Many newer hardware are currently mislabeled.
I've moved this to the speccy bugs board
Some other more up-to-date tools will list what family an Intel processor is in, and it can reference something older than what's actually installed in the computer.
