For over 24 hours I have not been able to get this function to work. I keep getting a message that there’s a technical issue and if it continues to restart my machine or contact customer support. Well I’ve restarted several times over the last 24 hours and it remains the same, and I can’t seem to find a way to contact customer support.
Is this happening to others or is it a fault with my laptop?
You can raise a support ticket by using the form here: CCleaner Support Community
(Do not try to change the language of that form, it has a bug and becomes unresponsive if you do that. If it happens then close and reopen your browser and try the form again without changing the language).
Note that support are slow to answer these days and it can take a week or more for a registered customer to get a reply.
Thanks, I will give that a try.
