HP CCleaner issue
Has anyone heard of CCleaner being an issues on an HP win7 machine?
I've used CC on many HP desktops and laptops without issue. (stub in the dark figure - easily more than a 100)
You'll have to give specifics.
I have an HP Win 7 64bit machine using CCleaner with no issues.
Are you saying it is an issue with the latest CCleaner build for you ?(4.11)
As mta said, you will have to give more info.
CCleaner interacts with the operating system, not the hardware; so it's immeasurably unlikely that it would cause issues with one specific PC manufacturer.
HI, Oldphil.
I have an hp win 7 64 bit machine.
No issues, but you'll describe the issue I'll try to duplicate it.
Well, one issue: Sometimes CCleaner fails to delete some of the cookies in the Sandbox, but that may be because the filenames are too long.
