Hi all. I just purchased CCleaner Professional PLUS.
How do I access the Disc Defragmentation, File Recovery and Hardware Inventory?
Many thanks
Bigyun2000UK
Many thanks
Bigyun2000UK
You need to download/install each one seperately and enter you registered name and key into each.
It's done that way so that you can pick and choose which you want to download/install and which you don't need.
To avoid all the marketing information you can download the installers for each from these simple pages:
CCleaner: <a href="https://www.ccleaner.com/ccleaner/builds" rel="external">https://www.ccleaner.com/ccleaner/builds</a>
Defraggler: <a href="https://www.ccleaner.com/defraggler/builds" rel="external">https://www.ccleaner.com/defraggler/builds</a>
Recuva: <a href="https://www.ccleaner.com/Recuva/builds" rel="external">https://www.ccleaner.com/Recuva/builds</a>
Speccy: <a href="https://www.ccleaner.com/Speccy/builds" rel="external">https://www.ccleaner.com/Speccy/builds</a>
Once downloaded and installed you go to 'Options>About' or 'Help>About' and click on 'Upgrade to Pro', enter your registered name/key, and then click 'Register'.
On 18/03/2021 at 22:04, Bigyun2000UK said:<div class="ipsQuote_contents"> <p> Hi all. I just purchased CCleaner Professional PLUS. </p> <p> How do I access the Disc Defragmentation, File Recovery and Hardware Inventory? </p> </div>
i have this question for some time ago...there should be a one file installer to download...
Quote<div class="ipsQuote_contents"> <p> If you download the Professional Plus installer (link in your confirmation email after purchase) then you should be greeted with this on the second screen after you select your language: </p> <p> <a href="https://content.invisioncic.com/d154966/monthly_2020_06/image.png.2a0d6a0df442f67316c9df0afab1519d.png" rel="external nofollow" title="Enlarge image"><img alt="image.png" class="ipsImage ipsImage_thumbnailed" data-fileid="13624" data-ratio="78.00" width="500" src="<fileStore.core_Attachment>/monthly_2020_06/image.png.2a0d6a0df442f67316c9df0afab1519d.png" /></a> </p> </div> </blockquote> <p> </p>
