I didn’t find anything about the command line parameters of recuva on internet, and I need to use the tool by this way. Please give me a list of all parameters of recuva to allow using it by command line, thanks!
i don’t thunk it has any cmd line parameters
I found one, /scan, by chance, but I don’t know anything else.
The only one that I know of is for the Recuva installer where a switch of /s will do a silent install.
There has never been any option to run Recuva without using it’s GUI.
Calling Recuva from the command line simply opens it’s GUI (no matter what switch you try you put after it).
