Hello !
I bought a router TP-link and want to know the best security options to use.
for :
AUTHENTICATION TYPE : (4 options)
1-WEP
2-WPA
3-WPA2-PSK
4-WPA-PSK/WPA2-PSK
which one is the best?
& 3 options for Encryption:
1-TKIP/AES
2-TKIP
3-AES
thanks in advanced
Use WPA2-PSK & AES if your devices support it, otherwise WPA-PSK/WPA2-PSK & TKIP/AES.
many thanks:
the device supports both : (1) WPA-PSK/WPA2-PSK + TKIP/AES. and (2) WPA2-PSK + AES
so (2) is the better than (1) for more security or they are all the same?
I meant the devices you connect to the network.
(2) would only use WPA2/AES which is better but is not supported so widely.
Usually anything but WEP is enough.
my device supports it (2). thanks a lot.
