The "Applications" tab in CCleaner still shows old programs I've removed long ago. For example, I still see Office 97, XP, 2003, 2007 as selectable entries, but I have _no_ Office installation at the moment. How do I remove these obsolete entries and clean-up my apps listings?
To find out all the rules (and their detect keys) you can
Type this into the run box on your PC
"C:\program files\CCleaner\ccleaner.exe" /export
The " are important. Replace C:\program files\ccleaner\ with the location of your ccleaner in it is in a different location
Then open "winapp.ini" and search for the programs that are ghosting, you see a "detect" or a "detectfile" this is how you'll know what is left over and needs to be deleted
