how to reinstall CCleaner
had to replace hard drive
have paid for pro CCleaner program
have two (2) numbers gotten when paid for pro programe
any help will be good
antpit
Hi anthpit, and welcome to Piriform,
As you are referring to a paid version of CCleaner, you're entitled to direct Piriform support.
You'll get help here ...
Piriform Support (Submit a request)
Hope that helps.
How do I re-instate cc cleaner.I now have licence number
You can get the standard build or the slim build (without toolbars etc) from here
https://www.ccleaner.com/ccleaner/builds
To enter licence ...Options.. About.. and press 'upgrade to pro' button.
There is now an instruction video in the documentation that shows you what Hazelnut said:
The steps shown work for updating from Free to Pro as well. (Putting in a valid license key changes Free to Pro).
https://www.ccleaner.com/support/ccleaner#204043844
i am fed up with all the question to reinstall for ccleaner that i paid for
