How to get it to NOT delete login cookies
How do I get CCleaner to NOT delete login cookies. I can;’t find the ‘options’ tab that the on-line help mentions. I have version 7 and it is completely different from the on-line help.
for custom clean it is in the settings button in the right hand pane
For Health Check you need to run a scan then you can find the settings button in the righthand pane.
