Why in the world did CCleaner get rid of all these icons on my computer?
None of the default image icons work on my Vista x64 Ultimate and a lot of other icons are missing.
Is there a fix for this?
I thought CCleaner was a respected app.
It is a respected app
Just as a quick try (as I don't use vista) have you tried this?
http://www.howtogeek.com/howto/windows-vis...-windows-vista/
it's not one icon.
its maybe 40 or 50 misc icons.
Are you able to use system restore to a time when your icons were there?
Are you able to do a repair of the icon cache?
Here a thread with some info on how to do that
http://www.eggheadcafe.com/software/aspnet...n-pictures.aspx
Did you have any other problems as well?
It is not really something that CCleaner does as it is quite a safe app, (although at the moment I'm sure you don't feel that way!)
I have had the same issue arising--after downloading the latest version of CCleaner upon my Windows 2000 machine, and, installing it. Immediatel gone were almost...all icons--but, a handful. Then, after a Right-Click upon the Desktop, and, clicking Refresh--I did manage to get...MANY icons back, again. Gone were...dozens, however with ALL (almost) re-arranged in ways different from originally. And, since ALL OF the spacing and most of the locations had changed: maybe, some of them are off-page (somewhere...I don't know)?
Any...(all) "answers", appreciated (I haven't rebooted since this fresh...install--NOR, have I run the latest version...installed; only installing it).
God bless...always.
Hey...after my initial steps--having only four or five icons left after the CCleaner download and install--doing a Right Click upon the Desktop, and, doing a Refresh: bringing back some icons, different sizing and spacing with MANY missing items...1. I have found that putting a bunch of IE links (from off my Desktop)all into one...folder--creating SOME ROOM thereby--and, then, doing a Arrange Icons a couple of ways (I think; at least, by Type), I have them all...back, again!
The task of...re-arranging themselves (as before); for another...day, likely?
Thanks...always!!
