Ok so there is nothing at all listed in my Mac's login items.. and CCleaners 'Preferences' is completely greyed out.. so short of uninstalling the entire app
how do I stop this thing from running when my computer starts up??
i dont have mac... but what is in "services"?
is this helpfull?
Trium, the MAC OS doesn't use services.
Whateva, we dont have a lot of MAC people who come by the forum. The developers read all threads, so they may ask for more information
Hi there,
Thanks for the information and I'm sorry you're facing this issue!
I've attached a screenshot of CCleaner's start-up modification tool - can you confirm whether CCleaner is in this list? If so, click on CCleaner and then click remove. This won't remove the application, but it will remove the app from start up.
Let me know if this doesn't solve the problem for you
Hi folks.. thank you for the replies.
No, CCleaner is not even in it's own list of startup programs. Nor is it listed in my account Login items which is very strange.
But I did find 2 instances of it in the /System/Library/LaunchAgents folder. I will delete them both and see what happens.
That worked.. it no longer starts up on boot.
