Path to App is C:\Users\manu\Documents\Startmen? Systemprogramme\Windows Tweaks+Zubeh?r\Zubeh?r\CaSIR +Anti-Malware Toolkit\RRT.exe
I know i can delete this key in ccleaner Extras-Autostart or msconfig,but is it possible to add this registry key to ccleaner.ini or winapp.ini so i dont have to click through the ccleaner menu?
I want to clean this key with start cleaner button.
The only question I have is, if you delete the key does it keep coming back? You should only need to remove it once. Unless the application creates the registry entry on every run.
I put it in winapp2.ini but the entry does not show up in ccleaner menu. And after cleaning the registry key is still there although before i already stopped RRT.exe from running .
