How to change temperature from Fahrenheit to Celsius?
When I go to check the System Info in the app it shows the temperature in the Fahrenheit, how to change it to Celsius?
Android 9 here!
Already changed temperature units in the Google Assistant, to no avail, obviously!
Anyone at all?
I looked and saw no way to change f to c in either the app or android globally. I think it's a good idea for Ccleaner to add.
On 22/03/2020 at 00:20, Nergal said:
It sucks that Android doesn't allow to change it globally!
Would be really great for the CCleaner team to make an update, coz this Fahrenheit is downright preposterous!
