How restore a installed entry, please help
I have removed several entries in my installed programs list. I need to restore a couple to uninstall them. Please help.
Three options I can think of:
  • Look in the program files folder for the software you wish to uninstall, some will create an uninstall file in their own folder like:
    uninstall.exe, unins000.exe, etc.
  • If you don't find those you could reinstall the software to fix the uninstall link, which would then allow you to uninstall the software.
  • Or you can use a current System Restore Point before you played around in the programs list, this will restore the registry and the uninstall link.
That covers just about all the easy choices. I've done option #2 quite a number of times with great success.
