I wish to use a USB3 External HDD and believe my only way is to add a PCI Express Card in my long x16 socket.
Tech. Support of the original seller of the motherboard will sell me a "long" card that uses the entire length of the x16 socket,
and assured me that it would give me the full benefit of the 5 Gbps capability of USB3,
and warned me that any smaller card that can fit into an x1 socket would give me only 2 Gbps,
and he quoted the small table on the right near the top of
http://en.wikipedia....iki/PCI_Express
I have now read all the above and have read
In 2003, PCI-SIG introduced PCIe 1.0a, with a per-lane data rate of 250 MB/s
PCI-SIG announced the availability of the PCI Express Base 2.0 specification on 15 January 2007.
The PCIe 2.0 standard doubles the transfer rate compared with PCIe 1.0 to 5 GT/s and the per-lane throughput rises from 250 MB/s to 500 MB/s.
followed by
PCI Express 3.0 Base specification revision 3.0 was made available in November 2010, after multiple delays.
The motherboard was supplied around May 2011
so I HOPE the supplier achieved 2.0 standard in those 40+ months.
Is there any freeware that can positively identify the PCIe version of my motherboard,
or do I have to pay the extra for a large card or attempt a "sale or return" on a cheaper small card.
According to Speccy :-
Motherboard Manufacturer ASUSTeK Computer INC. Model M3A32-MVP DELUXE (CPU 1) Chipset Vendor AMD Chipset Model 790FX Chipset Revision 00 Southbridge Vendor ATI Southbridge Model SB600 Southbridge Revision 00 PCI Data Slot PCI-E Slot Type PCI-E Slot Usage In Use Bus Width Unknown Slot Designation PCIEX16-1 Slot Number 0 Slot PCI-E Slot PCI-E Slot PCI-E Slot PCI Slot PCI Slot Type PCI Slot Usage Available Bus Width 32 bit Slot Designation PCI-2 Slot Number 5
Regards
Alan
