How apply on specific %systemdrive%?
Hello everybody!
How i can apply ccleaner on a specific system?
I mean that ccleaner not clean the own loaded system, but a nother Windows install anywhere.
(For example a mount from Image-Customization-Tool or a backup of existing system.)
I hope u know what i mean.
Hints would be greatfully.
Thanks.
Cannot, unless you were to painstakingly recreate winapp.ini to point to the non-live system. Ccleaner can be run from a flash drive on any system, but it will always only clean the system drive.
i guess you could change the systemdrive variable to point to another drive temporarily, but i have no idea whether or not this would explode your computer.
