Hi I Have A Problem With CCleaner When Analyzing Geting RUNDLL Error Loading InetCpl.cpl
Hi I'm New Here And I Would Like Know What Is This Error What Should I Do About And Also I Want Know If It's HarmFull To My PC.
When I Anyalying Under CCleaner Windows TAP I Get Three POP Up Error's.
Saying Error Loading InetCpl.cpl
The Specified Module Could Not Be Found.
I had this suddenly happen to me starting this morning, I found your post looking for a solution.
I did find a solution that worked for me-resetting IE7, it's pretty easy:
1) Open Internet Explorer (I have IE7, don't know if this will work in another version)
2) Click on Tools, then Internet options, then Advanced
3)Below the box of advanced settings is an option to Rest Internet Explorer Settings, click on the reset button.
4) Click on the confirmation pop-up, and close and restart IE7
It worked fine for me...and it looks like this may be an easy way to do a correction of IE settings w/o a reinstall!
Okay I Have Try That With The Tools Reset Thou When I Click It Geting More Error's
Restrictions
This Operation Has Been Cancelled Due To Restrictions In Effect Of This Computer . Please Contact Your System Administrator .
NOTE* That I Have IE7 Thinking Maybe Is Should Try Reinstalling.
Oh And I Would Like If SomeOne Will Tell Me When Next Relese Of CCleaner Will Be Coming Out?
P.S
Thank For The TIP Robmilmel
