Help, the cleaner is always clearing away my username and password in my web site.
Can someone teach me a way to stop it from cleaning away my password?
Thank you
Thank you
Either Turn off cookies cleaning or (better) tell it which sites you want cookies to remain on.
(Options Cookies)
Username and passwords are usually stored in the cookie unless you are telling IE to remeber passwords (p.s. DON't Do that)
...also Flash based cookies will be removed if you have CCleaner clean Adobe Flash Player located in Cleaner->Applications (tab)
