HELP!
For some strang reason now when ever i try uninstalling stuff it says uit uninstals it but it leaves a bunch of s**t in my programs folder. if i try deleting it it say "make sure your disk is not full or write-protected and the file is not curently in use" and i cheeck every thing and i should be able to delete it.
Later i tried using the program "Eraser" and it says every time i try to ersae it that "error: reached the end of the file." and it leaves the file there.
This is getting really annoying so i need some help as soon as possible.
Thank
1-check for possible spyware
2-delete the file(s) in safemode
3-if certain process is locking the file(s) try
http://ccollomb.free.fr/unlocker/
What are you uninstalling?
it's ok now i was able to get ride of them wit bergy help. Thanks anyway
