When i try to check my disk for errors (Check Disk) i get a message that says the disk is being used exclusivly... I dont understand, neither microsofts or Nortons works because of this error message. I am trying to check the hardrive i am running my OS on... Also as a side note, why do many people think Norton 2005 AntiVirus is a P.O.S.?? I find the System Works as a very usefull program.
Cant fix your problem but as to why norton sucks read this thread:
I'm not sure why you'd get a message about excusivity. Is this Windows XP? If it's NOT, then ignore all of the following, otherwise, try it out:
Start, Run... CMD
C:\Documents and...\>chkdsk C: /f
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N) Y
//---OR------ :
C:\Documents and...\>fsutil dirty set C:
(reboot)
@ DjLizard
What exactly does the command "fsutil dirty set C:" tell ChkDsk to do, and what parameters to use, e.g.; /f or /r
It sets the dirty bit on the NTFS volume which makes autochk (which runs every bootup via the BootExecute value in the Session Manager key) to perform a scheduled check (using /F). For /R you have to use the UI - right click the drive, properties, tools, check for errors, checkmark both boxes, then it'll tell you it has to restart. You can also do CHKDSK <drive> /R on the command prompt and if the drive is locked, it'll schedule a /R (via autochk, etc).
