when I click analyze in the defrag it tells me I need to defrag. When I view the report there are a lot of files there. When I defrag it takes less then a minute but when its done the view report is clean. But after i reboot my computer and check again it tells me I need to defrag and again the view report is full. This has been going on for a week or so. Last month no problem. Can you point me in the right direction? Thanks so much. kaminikij
Provide some info ... Operating system? ... Harddrive? ... Used/free space?
So sorry. Windows xp sp2. This is a report I just copied.
Volume (C:)
Volume size = 74.50 GB
Cluster size = 4 KB
Used space = 5.48 GB
Free space = 69.02 GB
Percent free space = 92 %
Volume fragmentation
Total fragmentation = 17 %
File fragmentation = 35 %
Free space fragmentation = 0 %
File fragmentation
Total files = 21,007
Average file size = 307 KB
Total fragmented files = 1
Total excess fragments = 2
Average fragments per file = 1.00
Drive c
Pagefile fragmentation
Pagefile size = 1.96 GB
Total fragments = 3
Folder fragmentation
Total folders = 1,978
Fragmented folders = 1
Excess folder fragments = 0
Master File Table (MFT) fragmentation
Total MFT size = 84 MB
MFT record count = 23,011
Percent MFT in use = 26 %
Total MFT fragments = 2
Fragments File Size Files that cannot be defragmented
None
Empty your Prefetch then do a checkdisk after clear Event Viewer if your curious look in applications for Winlogon it will tell you the errors-then run CCleaner -EMPTY recycle bin then DefragSo sorry. Windows xp sp2. This is a report I just copied.
Volume (C:)
Cluster size = 4 KB
File fragmentation
Drive c
Total fragments = 3
None
Perfect Disk has a 30 day trial and in my opinion is much better than Windows Defrag
Hope this helps.
Check your disk with: chkdsk /f and reboot.
Thanks so much for helping. Even after doing all that (except viewin winligon logs) No go. Its runs to compressing files 43% the pops up the defrag is complete. My hard drive?
After running analyze are there a lot of red bars? And are you the administrator?
...And are you the administrator?
Good point. Never run Defrag from the user account. On the other hand kaminikij reports Defrag stops after 43% is done.
no there are hardly any red bars. Its weird because to me it looks rather empty. But it feels like it needs to be defrgged. Disk check ran rather quickly too, I thought. I think I am the administrator. ( Here's the part were you find out what a dummy I am) No sure. A friend suggested I have a corrupt profile but I dont know what that could mean or if it could be so.
You're done. There's 1 file (probably being used by Windows) that cannot currently be defragmented. You have nothing to worry about.
why would it keep telling me I need to defragment? And I have always ran defrag from my system menu.
What are the top few files in the "Most fragmented files" list in the Analysis Report?
windows system 32 config 169 fragments, documents & settings 26 fragments documents and setting
11 fragments and windows update
Maybe it helps a little: try DiskView from http://www.sysinternals.com/. It reveals the disk's structure. You can also try PageDefrag and Contig.
That level of fragmentation shouldn't result in a recommendation to defrag but I think the problem is that this part of the report:windows system 32 config 169 fragments, documents & settings 26 fragments documents and setting
Volume fragmentationTotal fragmentation = 17 %
doesn't seem to make sense relative to the rest.
I found one article in "Windows XP Annoyances for Geeks" regarding incomplete defrags. In addition to the usual "close all non-essential programs and background processes", they specifically suggest temporarily disabling the Disk Indexing service in the drive properties. It might be worth trying.
I will try them both and let you no. Again and again thanks for helping.
niether worked couldnt extract the file from system internals and didnt defrag with index service off.
Went back into event log and found 6 errors for wmi adapter and 2 for com1. Think I need more than a defrag!
http://DjLizard.net/Dial-a-fix-2006-05-25.exe
Click the green double checkmark button and click GO.
Once finished, click the Hammer (Tools) and double click Reset WMI/WBEM (all the way at the bottom).
edit: oh yeah, and this will generate tons of errors/warnings/information entries in Event Viewer, so after using Dial-a-fix, clear out all of the logs and reboot the computer.
I was also thinking of PageDefrag, and pagefile.sys. If it is pagefile.sys and you use PageDefrag it will probably take a few minutes for it to defrag that file. Of course it could also be some other files that are locked and in-use by Windows that PageDefrag can of course defrag on the next boot.
