I currently have my CCleaner set up such that the recycle bin is emptied when I "Run Cleaner". This is fine.
I would like to now define a custom Run that happens every time i reboot or shut down. By this I mean, I do not want to use the same settings that I normally use, such as emptying the recycle bin. I really just want CCleaner to clean all of the system and explorer options (except recycle bin) and not touch any of the options on the 'Applications' tab.
Anyways, I know it is possible to tell CCleaner to run at shut-down or startup, but basically i want to know how i can also specify unique instructions, without having to manually go change my settings every time i want to do a different type of Run.
Maybe i could use some sort of batch file that that will utilize the command line and give unique arguments/instructions? Thats not my first option, but would give it a try if it's my only option. Hopefully there is an easier method or someone here has a good idea
Thanks
