I have spited Hard drive into 2 parts C: and F: CCleaner only scan C drive but how can i make it to scan F drive too?
Btw windows is running on C drive..
thanks
thanks
Do you have any installed programs on F:\? You can use the WinApp2.ini method to add custom programs, paths and files to clean.
More info here: http://www.ccleanerbeginnersguide.com/scr/winapp2.htm
User Guide (all topics): http://www.ccleanerbeginnersguide.com
I and other members will be happy to help you out with that. Just post back what on the F drive you need/want to clean.
