HELP WITH /AUTO
Could you have ccleaner automatically run at shutdown(in the background without seeing it) the way it automatically runs at startup or is the only way to double click the icon and wait 30 seconds?
There's a batch file at the end of the first post located in http://forum.ccleaner.com/index.php?showtopic=5143 which will allow CC to run during shutdown.
I think i might be doing something wrong then cause when i shutdown thru start>turn off computer>turn off, ccleaner doesn't run. The only way is if I double click the --ccleaner auto shutdown.bat-- icon which in 30 seconds will run ccleaner before shutting down. I also tried to create a shortcut of --ccleaner auto shutdown.bat--and insert / auto after the target but it only does the same as double clicking original icon.
The batch file is to only be used by itself! Simply double clicking it if you unzipped it to the desktop will suffice. Or as instructed in that thread I linked to you can also unzip the batch file into the CCleaner program folder and then create a shortcut to it anywhere you wish such as the desktop for example. It isn't rocket science. ;)
I swear I made that exact thing already.
