Help whith Monitor Position *1024x768
Ok, I'm fed up and can't help myself. I'm using res. 1024x768 and my corners are so... messed up. i can't seem to get it straight. Is there a program out there that can help me?
this may be worth a try,
http://www.surfpack.com/software/resolution/
i just googled for it..
Not quite what I'm looking for and the program doesn't work. Thx trying to help.
I could be wrong but I don't think its possible for software to control that part of the monitor. I know there is software to adjust the colors but thats usually for the video card or the system color thing in display properties. But the thing that shapes the monitors viewing angle(not the right way to describe it but I'm not sure what the right term is :P) is not controlled by the computer but by the monitors internal controls.
I know that. But the way HP programmed the corners id awful. I can't seem to get the middle part straight and nor... can I get the bottom corners straight. Which I had a LCD Moniter though...
Is it a flat screen crt?
Yes
