Yesterday, I successfully upgrade to XP SP3(no big deal).Now, windows always notify me to install net.1.1 SP1.I tried to install it but failed and failed again. How to solve this problem ? is it important to install it ?
OS : XP Pro SP3
NET.FRAMEWORK 1.0,2.0,3.0 & 3.5 INSTALLED
AVIRA free
Thank for the support
Hi Abu,
Nice seeing you again.
This guy has the "magic" when it comes to .NET framework.
I have used his tool a few times. Bookmark and save it to Favorites, this time.
I find that I have enough problems in life without creating more for myself.
This includes "cleaning" the Registry and also trying to save a few bytes by removing parts of my Windows OS. Life can be more fun if we just keep it simple!
Good luck and see you later,
davey
BTW, have some fun with people you enjoy !
Thank for quick answer,Davey
I used the cleanup tool to remove net 1.1,2.0,3.0 & 3.5.Now what ? Reinstall them ? or leave it alone and just install the latest 3.5 SP1 ?
will it affected my OS?
Thanks a lot
I would install them all and eliminate any future problems that way.
davey
P.S. I have them all installed and never encountered any problems.
It is mysterious sometimes . Whenever I have my tools in the trunk of my car, I never have any breakdowns. If I don't have my tools, Bang! something breaks and there I am with no tools.
I would rather have my tools with me and not need them then the other way around.
davey
I would agree with davey and Ken, although I don't have 3.0 or 3.5 installed myself, yet. If you're missing the earlier ones, you will probably at some time hit backwards compatability problems with software written on the earlier platforms.
