Help please - Autocomplete Form function disabled after cleaning
I used CCleaner (not sure which version - I've upgraded at least twice since this problem happened) to clear the Autocomplete Form history of IE. Immediately after cleaning, I unchecked the same box in CC, as I still wanted IE to autocomplete forms - I just wanted a one-time clean to get rid of the form clutter, in other words.
Ever since this cleaning, the form autocomplete function will not work. Any suggestions? Autocomplete is enabled in my Internet Options, both on the Contents tab and in the Misc tab. Also, I use Avant Browser, and Autocomplete is enabled there. Still, no autocomplete even after I just today installed the brand new version of Avant.
My system (it's pitiful):
Win98, all updates
IE 6, all updates
Avant 11.0-21 (new version)
CCleaner v1.32.345 (haven't snagged the update yet)
Please let me know if you need any more system info.
Many thanks!
Chuck
welcome to the forums :D
please run this batch and tell me what comes up in the notepad.
you'll see what i mean ;)
http://forum.ccleaner.com/index.php?act=At...post&id=979
