Help, overwrite
I am working in MSWord. I created a document of 68 pages and saved it as 121107. I then created a new document of 3 pages and accidentally saved it as 121107. It has now overwritten the one of 121107 and it did not create a backup copy. Is there any way I can recover the first document called 121107?
Deleted, probably yes.
Overwritten, probably no. :(
You can try Recuva to get that original file.28 pages is worth the effort.
If you do ,don't forget to change the name.Don't want to lose the other 3 pages.
Good Luck,
:) davey
P.S. Learn from this.Make your names more unique.
Good Luck,
:) davey
It was 68 pages!!! I did try with Recuva but no luck. I used the date of the hearing for the name of the document. I completed the one for 21 November, then called it up and used it to start a hearing on the 22nd. I changed the date at the top of the page from 21st to 22nd, deleted the rest of the document and went on typing merrily. Then I pressed Ctrl-S and that's when I saved it with the wrong name. Stupid, stupid me. It's not the first time I have done it. Do we never learn?
Thanks for suggestions.
