Hi guys, Been awhile   .
Seems CCleaner isn't removing these Issues. When I tried to open in RegEdit it came with ERROR: Cannot open .APL: Error while opening file. Any Ideas to solve it? Screenshot below. *Total 106 Problems.
Try Dial-a-fix's Repair Permissions. One big problem is at the very bottom of the list as it looks like CCleaner is detecting it's own CCHelper.ocx ActiveX control registry data.
Thx but what sections should I be checking before conituning the repair?Try Dial-a-fix's Repair Permissions. One big problem is at the very bottom of the list as it looks like CCleaner is detecting it's own CCHelper.ocx ActiveX control registry data.
Please clarify, I don't understand your question. Are you talking about CCleaner, or Dial-a-fix?
Sorry, was meaning Dial-A-Fix
Not used Dial-a-fix for a while but I think you click the tools button and select 'Repair permissions' from there.
All done! Thx guys
