Registry errors found & cleaned while running Ccleaner
Questions : If I delete & repair them they return on rebooting system.
Are they safe to add to Exclude list?
That .REG file won't load/download and really isn't the type of thing to post on a forum anyways. It's better to post such things as plain text on the forum, or upload as a .txt document then anyone looking at it can't accidentally import it into their registry.
"Registry errors" that keep returning are usually because Windows or some program is re-creating them, you can exclude them. Or don't clean the registry at all, and if using Windows 10 you're better off not cleaning it.
I had no problem downloading that .reg file and opening it with notepad.
It contains just 3 registry keys.
[HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store]
"C:\\Windows\\System32\\igfxTray.exe"=hex:53,41,43,50,01,00,00,00,00,00,00,\
00,07,00,00,00,28,00,00,00,e8,ab,05,00,1f,43,06,00,01,00,00,00,00,00,00,00,\
00,00,00,0a,73,22,00,00,67,07,7c,ba,c5,4c,d4,01,00,00,00,00,00,00,00,00,02,\
00,00,00,28,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,8f,6b,a7,00,00,00,00,00,03,00,00,00,03,00,00,00
"C:\\Windows\\System32\\igfxHK.exe"=hex:53,41,43,50,01,00,00,00,00,00,00,00,\
07,00,00,00,28,00,00,00,e8,c1,03,00,80,7b,04,00,01,00,00,00,00,00,00,00,00,\
00,00,0a,73,22,00,00,67,07,7c,ba,c5,4c,d4,01,00,00,00,00,00,00,00,00,02,00,\
00,00,28,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,0c,6c,a7,00,00,00,00,00,03,00,00,00,03,00,00,00
"C:\\Windows\\System32\\igfxEM.exe"=hex:53,41,43,50,01,00,00,00,00,00,00,00,\
07,00,00,00,28,00,00,00,e8,11,08,00,cb,8b,08,00,01,00,00,00,00,00,00,00,00,\
00,00,00,00,00,a8,6c,a7,00,00,00,00,00,03,00,00,00,03,00,00,00
The key is related to the executed programmes list.
The 3 entries are all related to Intel graphics.
igfxtray.exe is a 'Graphics Accelerator Helper Module' for Intel and nVidia graphics cards.
igfxHK.exe controls video-related hot keys as part of Intel's Common User Interface.
igfxEM.exe is the executable of Intel's Common User Interface.
They should be OK to ignore/exclude.
But as Andavari said you are better off (safer) not using the reg cleaner at all with Windows 10 (unless you have a particular problem).
It will not speed up your machine or save space, and has been know to cause problems and even brick machines altogether.
