Hello Folks!
This "Uninstaller" interface is associated to 'Clover', the Program which claims to add Tab-functionality to the Windows explorer interface!
Iam done with it, & wish to Uninstall the same. However, the Foreign-Language interface is proving to be an impediment in this task!
Can someone please help decipher the various Options listed out there against the enclosed reference, & guide further in this regard?
I would always prefer a 'Total Uninstall' & would not like to retain any of the User-configuration, User-settings..etc. etc.
Please suggest....
Thank you.
![post-69563-0-13262200-1471459982_thumb.jpg]()
The author has a blog where you might try posting your screenshot. Its on the company website. Its multilingual.
Not going to post the link here, looks iffy, but others who know more might post it.
Also, if you can copy and paste the text from inside that popup, google translate might tell you what it means.
If all else fails version 3.1.2 has multi language support (15th August)
Perhaps install it over the top and you may get the English version and then can uninstall.
Make restore point/image first.
http://www.techspot.com/downloads/5856-clover.html
Hello Hazelnut!
Iam using the Latest version already!....as is evident against the attached reference.
To login 123:
I did post the query on the same a few days ago & there hasn't arrived a revert yet!?
The text on the Uninstaller window cannot be copied & would probably require a suitable OCR App to uncover the same..
Therefore, please help Pool-in Volunteers support for the cause.. :-)
Thanks.
![post-69563-0-21047700-1471533568_thumb.jpg]()
So the top selection google translates to "Key fix 'to upgrade to the latest version upgrade to the latest version Fun new features." So maybe it's repair or keep settings
The second choice says
"● straight seam Thank you for using the 'we will strive to improve" maybe uninstall?
I couldn't get translate apps to figure out the buttons and as 1 is c and the other n, they both could be the ok (with one being No or the other being cancel) edit: but based on the second shot I'd say the one on the left is ok
Thanks to all Dear members!
I have been able to retrieve the reply from the Author's Blog, & here it goes for the common Good!
Mission accomplished. :-)
![post-69563-0-74886100-1471718959_thumb.jpg]()
Thanks for posting back how you fixed it.
I really like your translations.
Never knew the Chinese characters for "bla bla bla".
:lol:
:lol:
Hello login123,
The final screenshot is a handiwork of the Author/ or probably some other active member of that Community.
This is how he narrated things to me. :-)
Thanks.
