I Installed CCleaner to my director's computer.I ran it.Then it deleted some files but I dont copy registery files.After sys. recovery of windows gave error and never run again.How can I correct my mistake .Please someone helps me.
error :"The system recovery dosn't protect your pc.please restart your pc and try it again."
it is xp home edition sp2.when it tried to register it asked me to whether save or not i replied no and did not save it.because i didd it before and i did not save them and there was no problem for them(other computers)meanwhile thank you for replying my enquiry.hope to write me back. best wishes
Did you say you did a system recovery or a system restore?
If you tried a system recovery that is not good news.I would definitely wait and talk to the director.
If you tried a system restore, did you try a system restore from an earlier Restore point?
Do you happen to use ERUNT?
You could try this until she returns or wait until she replies.
She is a very knowledgeable Moderator.
Good Luck,
davey
P.S. Second thoughts are that good directors understand that mistakes happen.Tell the director what happened, what your plan is to resolve the problem, and let the director decide what should be done.
thanks to everybody who care about my problem.thanks a lot.I solved the problem by upgrating system by using windows cd.now the system restore is active and the director won'T kick me:)this time I am lucky and I recovered the system with acronis and copied it.from now on i won't care about my back:)thanks you alot again.best wishes for you and your pc's hazelnut and davey.
