Mewebe
12 November 2009 12:06
1
I have 2006 Hot Uninstallers using 500 Mb, which I would like to remove, but I don't know the consequences. Is there any help for the advanced cleaning features?
P.S. the CCleaner web tag has been hyjacked by PCCleaner. I downloaded the wrong software initially.
metalj
12 November 2009 19:48
2
Hotfix Uninstallers will delete windows update installation files.
(you can delete them if you don't plan to uninstall windows updates)
More on the advanced section here .
Way more on docs.piriform.com
From where did you download from?
Nergal
12 November 2009 22:45
3
MetalJ PCCleaner dot com and tucows both carry this program, that said, I didn't look to see if any infringment was occuring
However I also found this
Not sure if they are related
http://www.2-spyware.com/remove-pccleaner.html
also in 2004-2005 the site was replaced by a fbi cyber squad warning
was rebought from godaddy in (august) 2007 and started distribution some time after aug 2008
