It first happened when I was checking email, and now it's happening while I'm watching a video on the internet. It's like a grinding/scratching sound coming from the HDD. Nothing appears to be wrong with my files when this happens, but I was hoping that I could post my HDD's Speccy report and see if something is bad. Check it out:
Hard Drives TOSHIBA MK5065GSX ATA Device Manufacturer TOSHIBA SATA type SATA-II 3.0Gb/s Device type Fixed ATA Standard ATA8-ACS 48-bit LBA Supported Serial Number 80QIB1LFB Interface SATA Capacity 488GB Real size 500,107,862,016 bytes S.M.A.R.T 01 Read Error Rate 100 (100 worst) Data 0000000000 02 Throughput Performance 100 (100) Data 0000000000 03 Spin-Up Time 100 (100) Data 00000007C1 04 Start/Stop Count 100 (100) Data 00000002C4 05 Reallocated Sectors Count 100 (100) Data 0000000000 07 Seek Error Rate 100 (100) Data 0000000000 08 Seek Time Performance 100 (100) Data 0000000000 09 Power-On Hours (POH) 099 (099) Data 0000000278 0A Spin Retry Count 114 (100) Data 0000000000 0C Device Power Cycle Count 100 (100) Data 00000002C4 BF G-sense error rate 100 (100) Data 0000000016 C0 Power-off Retract Count 100 (100) Data 0000000006 C1 Load/Unload Cycle Count 100 (100) Data 0000001802 C2 Temperature 100 (100) Data 00000F002D C4 Reallocation Event Count 100 (100) Data 0000000000 C5 Current Pending Sector Count 100 (100) Data 0000000000 C6 Uncorrectable Sector Count 100 (100) Data 0000000000 C7 UltraDMA CRC Error Count 200 (200) Data 0000000000 DC Disk Shift 100 (100) Data 0000000047 DE Loaded Hours 099 (099) Data 000000019B DF Load/Unload Retry Count 100 (100) Data 0000000000 E0 Load Friction 100 (100) Data 0000000000 E2 Load 'In'-time 100 (100) Data 0000000157 F0 Head Flying Hours 100 (100) Data 0000000000 Temperature 114 ?F Temperature Range ok (less than 122 ?F) Status Good Partition 0 Partition ID Disk #0, Partition #0 Size 100 MB Partition 1 Partition ID Disk #0, Partition #1 Disk Letter C: File System NTFS Volume Serial Number A81A205E Size 466GB Used Space 107GB (23%) Free Space 359GB (77%)
