Hardware Analysis?
So if I purchased the Professional Plus version, it includes "Hardware Analysis". Exactly what does that do? (Hopefully check for driver versions?)
Thanks,
Ray
Hi Ray, and welcome to the forum.
CCleaner Pro+ as you probably know is a package containing Professional versions of CCleaner, Defraggler, Recuva and Speccy.
The "Hardware Analysis" you mention being covered by Piriforms "Speccy" program. (Not a driver scanner)
Some info here ...
http://www.piriform.com/speccy
... and Speccy docs here ...
http://www.piriform.com/docs/speccy
Hope that helps.
