Hi!
I've a suggest for you.
You must be included a viewer of select file?
It's more simply for restore a Text file or other.
P.S: Sorry for my english!
Hi!
Hi There,
I would like to see the 'Select Drive' Option longer or the drop down list expand dependant on the length of the drive name. I have all my drives named so that I can remember what they are used for, but they are not showing up fully in the field or drop down list.
Kind Regards
c|(:op)+<
