The Attached Thumbnails by trium, are for Windows,
shows Google Earth, in Windows, Aplications applys a box to check if you want it cleaned.
In Windows when you use both Google Earth, & Google Earth Pro, it shows in Applications, as "Google Earth."
and trium's registry Attacthed Thumbnails, is for Windows.
Works in Windows, not Mac.
In Mac,
Google Earth, applys the entry box in Applications, when only opening Google Earth.
Google Earth Pro, when opened does not apply the box, fails to make a Google Earth entry.
Before Google Earth was free, the same Mac problem existed.
I will be using Piriform Mac competitors until this bug is fixed.
The last Mac CCleaner version 1.09.313 was Sept 16, 2014.
Now that Google Earth Pro is free, should this thread be expedited & moved to
CCleaner for Mac or CCleaner Bug Reporting?
I know the Moderators read, few post. I hope somebody has brought this to the proper attention to correct.
