Hi, a few weeks ago GIMP 3.0 has been released: it’s installed in “3” directory instead of “2” (it didn’t override previous installation, but created a new parallel one) and probably has another fingerprint, but Ccleaner doesn’t consider it for update.
Now, I removed the 2.x installation and it neither notices I have Gimp installed
Hi, same problem here, upgraded Gimp now about 12 times from 2.x to 3.0.2-1. I only see a “Gimp 2” folder in Program Files, no “Gimp 3”. Does ccleaner stop complaining? Then I might do the same. Just uninstall Gimp 2.0. There is an uninstall folder there, just not sure if I lose all my wifes’ settings..
I noticed a Gimp 2.x and a Gimp 3.x installed in windows control panel/apps & features or add and remove programs or something similar (programma’s en onderdelen in dutch). So I removed 2.x. Ccleaner stopped complaining. Fingers crossed ![]()
Gimp 3.0.4 is out now, but CCleaner still doesn’t detect it.
@Aart, did you solve how to import the settings?
I dind’t. But loosing them wasn’t a big problem. Ccleaner stopped bothering me about the update.
Looks like CCleaner 7 detects Gimp 3.x, but I just updated to 3.0.6 and he didn’t notice my 3.0.4 was to-be-updated.
…and it finally detected 3.0.6.1! ![]()
