CAN YOU EXPLAIN WHAT ALL THE COLORS USED IN DEFRAGGLER INDICATE?
AN ONSCREEN COLOR LEGEND WOULD BE HELPFUL.
You can find the Legend in the Help menu.
I would just like to add, yes it's there under one of the menus but having it off to the side on the main screen would be really nice.
I would also like to see the "active blocks" section as large as possible. I know you can drag the panes up and down, but the bottom pane still must remain very tall. It would be nice to see that information that it does display, moved out to the sides a bit more. There's a lot of wasted white space on the right side of that pane and it would be nice if the STATUS and PROPERTIES were stretched out to fill it horizontally instead of stacked vertically.
