Future Products?
I've been really interested in when the new programs are going to come out. But it has said later this year on the site since almost two years ago.
I'm patient and all, but your other programs are awesome. What's up?
When Piriform release them or a beta version is when you know about them.
Defraggler was one of those future apps.
It's probably best Piriform keep apps quiet till they are beta ready anyway,
Less ideas likely get stolen before release and no broken dreams of Piriform fans if it didn't work out..
Thanks. Makes sense now. Any ideas if "anything" is on the way? Supreme secrecy can still be kept.
Unfortunatly no, I'm not internal so I don't get that kind of info.
And then if I was (*please* :) ), most likely I wouldn't be permitted to say.
Thanks again. Also makes sense.
Aw well, I tried. How about an internet accelerator? Just as an idea. Then we would have a full work up. PC cleaner, undeleter AND secure deleter, and defragger. An internet accelerator or a tweaks/ full optimizer is the next big step.
Upgrade your connection speed. Although I must say if the Windows settings are incorrect that will make a connection crawl, however it depends upon what the settings are if you even notice a difference.
I have high speed, I just thought that a general tweaker/ optimizer would round out the lineup. And I ask my computer for the bleeding edge in Internet speed because I remember my Dial Up days. And I'm never going back......
A simple optimizer would just round out the lineup. I'd like it even more if it integrated with the rest of the programs, click to run...
Just suggestions.
I find that XP does a great job of keeping my DSL connection in tip top shape and then it is only the conversation between the DSL modem and my systems as the DSL modem configuration is not mine to control.
Thank &Deity I do not have to put up with all the inconvenience of dial-up any more.
