It is here. Win xp, Firefox portable 48.01.
I know, old stuff, but the slowdown doesn't affect other sites or forums.
The little spinner wheel grinds for 3-5 minutes on each link.
Or, sometimes, not.
Just an FYI.
Or, sometimes, not.
Just an FYI.
Happens quite often to me too login, and for quite a while. (months if not longer).
Admins are aware of this but don't seem to be able to find a reason for it.
Hi there
Thanks for the notification. We are aware that there are some issues. If this continues for you, please let me know!
Thanks.
OK. Thanks for the quick reply. All is OK here now.
Try this old trick I use (not guaranteed to always work though):
1. Open a new tab or new window in your browser, and pull up the forum in it, you should already be logged in when doing so.
2. Close the original window/tab.
Sometimes doing that will allow it to function faster.
"Try this old trick I use (not guaranteed to always work though):"
Sometimes works. Thanks.
You could try closing the browser and running a nifty little program called CCleaner to clear out all the cookies and stuff that have accumulated during your browsing session, that usually speeds things up again. LOL.
I know you're joking, however it's the forum/site that gets very slow sometimes, and sometimes it's unusable.
Helps to make sure the site isn't down using Down For Everyone Or Just Me:
