Forum email problem
Seems that not all of a message posting is being sent by email. Case in point:
============ Begin Paste =================
CSGalloway,
randomcore has just posted a reply to a topic that you have subscribed to titled "Get the Latest Winapp2.ini File".
------------ QUOTE ----------
why to exclude the virtual RegHives? can get wiped, too.
if you clear the sandbox using sandboxie control the RegHive file won't remain. everything behind your username will be deleted. so after cleanup there is no "DefaultBox" and because of this there are no RegHives inside of DefaultBox. the only file that remains is "DONT-USE.TXT"
The topic can be found here:
http://forum.piriform.com/index.php?showtopic=29438&view=getnewpost
If you have configured in your control panel to receive immediate topic reply notifications, you may receive an
email for each reply made to this topic. Otherwise, only 1 email is sent per board visit for each subscribed topic.
This is to limit the amount of mail that is sent to your inbox.
Unsubscribing:
You can unsubscribe at any time by logging into your control panel and clicking on the "Manage Watched Topics" link in the "Forums" tab.
============ End Paste =================
Can this be fixed please?
Are you using IE9?
Also I think the poster may have edited his post.
I think it's more that the email system is told not to include either quote or code (my emails look the same)
here is the original post
(...) I'd like to see an option to erase the contents of Sandboxie's default container folder. (...)
ExcludeKey1=FILE|%SystemDrive%\Sandbox\%UserName%\DefaultBox\RegHive*
