Since being on holidays this week, I've had to use the iPhone & iPad to access the Piriform Forum.
Things like emoticons and text formatting are missing and I was wondering if there is an easier way to do things instead of using HTML tags and similar.
Like is there a mobile app for iDevices, I have looked but couldn't find anything useful.
Yeah, I've switched the 'skin' over to that, but that's all it seems to do, just change the cosmetics, not the functionality.
Like, right now, I have no smiley face bar under this reply box and none of the icons to change bold, italics, bcc codes etc along the top. Makes formatting text a painful exercise (like to insert that wink I had to type ; and ) but I may just have to get used to it.
Most likely an iOS limitation.
Any other Android mobile device members have a similar prob?
