formating hard drive
alrighty. i erased the partitions for my 250 gb external hd and now want to format it. can someone help me here? its been a long time since i did this. thanks guys. your suggestions and help have been great thus far. :)
NTFS definitely. Actually NTFS is pretty much the only choice for 250 GB partition. AFAIK You can't format such a huge partitions with any other windows file system. Not with windows tools anyway.
Edit:
+ There is the famous 4 GB file size limit on FAT32 ;)
I use ext2 on my 250gb external hdd in Windows for compatibility reasons.
These days I hook up any drive as a slave, right click and format.
