For Quicker Use...
Make CCleaner a one-click operation...
I've got CCleaner set to clean and close.. but the need to click "run cleaner" is just an inefficient pain in the B...
I'd like to click the quick-launch icon, and have the program do its thing zipzop, and gone... I use CCleaner after nearly every process.. like right after closing the browser, or right after booting On.. or after a lot of photo editing work...
In my quick launch strip, I have: Cacheman Memory Restore, CCleaner, EasyCleaner, ScanDisk, and Defgrag...
Throughout the use of the PC I often run: Cacheman, CCleaner, and EasyCleaner to check the Startup cleaner for additions just in case an unscrupulous website added something that needs a reboot to infect the hd.. and at the end of the day I run ScanDisk and Defgrag after those three... It's a simple formula that keeps this old W98se running fast and smooth, after I've dumped everything macromedia and shockwave to stop the freezes and hold-ups.. Those two programs are just too aggressive for the older OS's.. and are the whole reason for thousands of W98 lockup web pages... After an OS install, and peripherals, I immediately run CMDiskCleaner's custom registry search, for what I call "The Three Poops": macromedia, shockwave, backweb, showbehind, and desktopmessenger... Then I run Spybot S&D, and the other cleaners...
Once the trojans and the "5-poops" are flushed out of the system, it never ever crashes nor freezes... Maybe CCleaner could add some of the features of those other cleanup programs, to make a complete cleanup a single click affair..?
It would be sweet if the old version of TinyPersonalFirewall was added to CCleaner... It's not so much a "firewall", as it is an internal "splashguard"...
Diect download link edited out by moderator
CCleaner has a one click operation, right click 'run cleaner' on recycle bin. So technically this is 2 clicks but you get my point.
As for adding the firewall idea, where is the sick smiley?
ignore that ^^^^^^^^^^^^ Just re-read what you said.
Essentially your post was just for you...
I suppose that's as close as you could come to flaming as you dare to in this reference forum...
Essentially you've said Nothing, but a goofy opinionated complaint, a poor attempt at flaming, and a comical "three-monkeys" attempt at insulting...
I searched your handle here, to find that all your posts say essentially nothing, but a series of mindless almost illiterate attempts at communicating your bits and pieces of unrelated opinions... I doubt this forum was intended to be your gossip knitting-club, nor is it your spider's web...
One click op is a good idea.. after all, the computer tends to grow to be the very essence of efficiency...
Maybe you should try to Grasp my initial post by reading it a hundred times or more, if you can.. and since you are into initiating flame wars, you might want to try to attack me in other forums which can handle four letter word battles, and worse, rather than you playing it sneaky and snidy here...
Surf: "cosmicbrat", and meet me as your great christian-bully, somewhere where the mummy mods can't protect you from your incessant bullying of innocents... I would just love the have opportunity to turn you inside-out in "michael's flame warriors", as "CB"...
So where's the smilie for "the melted/trashed mindless internet bully"..?
This thread stops right here gentlemen.
